Lumia 950 neuf
Lumia 950
Microsoft Display Dock Hd-500 - Station D'accueil - Pour Lumia 950, 950 Dual Sim, 950 Xl, 950 Xl Dual Sim
Nokia/Microsoft Microsoft Lumia 950 (black) débloqué logiciel original
Largeur:73.2 mm Hauteur:145 mm Composants intégrés:Caméra arrière, caméra avant, radio FM, lecteur audio, enregistreur vocal, haut-parleurs stéréo, navigation Facteur de Forme:Tactile Couleur du boîtier:Noir
Nokia Full Lcd Display Screen Touch Digitizer+Frame For Microsoft Lumia 950 Xl Black
Microsoft Lumia 950 Smartphone double SIM 4G 13.2 cm (5.2 pouces) 1.8 GHz Hexa Core 32 Go 20 MPix Windows® 10 noir
- Type: Touch Phone- 2G Network: GSM 850/900/1800/1900- 3G Network: HSDPA 850/900/1700(AWS)/1900/2100- 4G Network: LTE band 1(2100), 2(1900), 3(1800), 4(1700/2100), 5(850), 7(2600), 8(900), 12(700), 17(700), 20(800), 28(700), 38(2600), 40(2300)- Sim-type: Nano-dual-SIM- Dimensions:- Weight: - Displaysize: - Displaytype: - Memory int.: - Card slot:- Keypad: full touch- Datatransfer: GPRS, EDGE, GSM, HSDPA, LTE- Connectivity:- Features: - CPU: - Camera: - Oper.System: - Stand-by: - Talk time: - Sp ecials:
Nokia/Microsoft Microsoft Lumia 950 (blanc) débloqué logiciel original
cated mic, MP3/WAV/eAAC+ player, MP4/H.265 player, OneDrive (15 GB cloud storage), Document viewer, Video/photo editor - Type: Touch Phone- 2G Network: GSM 850/900/1800/1900- 3G Network: HSDPA 850/900/1700(AWS)/1900/2100- 4G Network: LTE band 1(2100), 2(1900), 3(1800), 4(1700/2100), 5(850), 7(2600), 8(900), 12(700), 17(700), 20(800), 28(700), 38(2600), 40(2300)- Sim-type: Nano-SIM- Dimensions: 145 x 73.2 x 8.2 mm- Weight: 150g- Displaysize: 5.2 inches- Displaytype: AMOLED capacitive touchscreen, 16M colors- Memory int.: N-A- Card slot: yes up to 200 GB- Keypad: full touch- Datatransfer: GPRS, EDGE, GSM, HSDPA, L TE- Connectivity: Bluetooth, Wi-Fi, NFC- Features: GPS- CPU: Dual-core 1.82 GHz Cortex-A57 & quad-core 1.44 GHz Cortex-A53- Camera: 20 MP, 4992 ? 3744 pixels, Carl Zeiss optics, optical image stabilization, autofocus, triple-LED RGB flash- Oper.System: Microsoft Windows 10- Stand-by: max 288 h (2G) / max 288 h (3G)- Talk time: max 23 h (2G) / max 18 h (3G)- Specials: Microsoft Continuum support, Wireless charging (Qi-enabled) - market dependent, Fast charging, Active noise cancellation with dedi
Belkin Support de voiture pour Porte-Gobelet Compatible iPhone 11, iPhone 11 Pro, iPhone 11 Pro Max, XS, iPhone XS Max, iPhone XR, iPhone X, Appareils Samsung, LG, Sony, Google, etc.
Ce support tient parfaitement dans le porte-gobelet de votre voiture pour vous permettre de maintenir votre smartphone en place lorsque vous êtes sur la route Monture pivotant à 360° pour positionner le smartphone en mode portrait ou en mode paysage et possibilité d'incliner le support de façon à obtenir l'angle de vue parfaite La base du support est extensible pour vous permettre de l'utiliser dans n'importe quel porte-gobelet de votre véhicule. Vous pouvez donc facilement transporter ce support d'une voiture à l'autre L'ouverture à la base du support de voiture permet d'éviter à votre câble de recharge de s'emmêler, et facilite la connexion de votre téléphone lorsque vous êtes sur la route Compatibilité universelle : Ce support est compatible avec la plupart des iPhone, Samsung Galaxy, Huawei, LG, HTC, Sony jusqu'à 8 cm de large S'attache solidement au tableau de bord ou à la fenêtre
RampowT01 Câble USB Type C à USB 3.0 - Câble USB C Nylon Tressé en Fibre avec Connecteur Ultra Résistant - Chargeur USB C Charge/Synchro Ultime Rapide - 1m/3.3ft - Gris Sidéral
💯 [Compatibilité Etendue] - Compatible avec Samsung Galaxy S10/S9/S8/Note 9/Note 8/A8s/A8 2018/A7 2017/A5 2017/A3 2017, Huawei P30/P30 pro/P20/P10/Mate 20/Nova 4/3/2, Honor 10/9/8, Oneplus 6/5/5T, LG G6, Nexus 5X, Asus Zenfone, Sony Xperia, Apple New Macbook, ChromeBook Pixel et d'autres appareils avec une connexion USB Type C 2.0/3.0. 🔋 [Synchronisation et Charge Rapide] - Profitez de la vitesse de transfert et de la synchronisation Très Rapide de 5 Gbps avec des périphériques USB 3.0, qui est 10 fois plus rapide que USB 2.0 (480 Mbps). Ce câble usb type c de Haute Qualité supporte jusqu'à 5V / 3A de charge en sécurité, vous permettant de recharger vos appareils plus rapidement que jamais! 👍 [Matériaux Premium] - La veste en nylon ultra-solide rend ce chargeur usb c résistant à plus de 16 000 flexions. Connecteur sans soudure et contacts dorés assurent une conductivité et une stabilité fiables et exceptionnelles. Conçus pour résister à plus de 12 000 insertions, branchez et débranchez vos appareils sans aucun soucis. 🌈 [Qualité Contrôle de 24 heures] - Chacun de nos câbles est testé sur 3 appareils usb type c différents pour une qualité de recharge optimale et fluide. Nos tests sont effectués dans des réalistes afin d'assurer une durabilité maximale au produit et prévenir tous dommages dus aux surcharges. 💗 [Garantie à Vie] - L'achat comprend une GARANTIE A VIE assurée par Rampow. Service client efficace et facile à joindre pour résoudre tout votre problème en 24 heures.
roxs Polarcell Batterie pour Microsoft Lumia 950-3200 mAh
Batterie de qualité supérieure - Protection contre la surcharge, la surchauffe et les courts-circuits Lithium-ion (faible effet de mémoire). Capacité : 3200 mAh Remplace le modèle BV-T5E Compatible avec Microsoft Lumia 950 Dual SIM
Rampow Adaptateur USB C vers USB OTG 3.1 - Adaptateur USB Type C Mâle vers USB A Femelle pour Samsung S8/S9/S10, MacBook Pro, Google Pixel/Chromebook, Huawei P20/P30 [Lot de 2] Gris Sidéral
😊 [USB OTG Soutenu] - L'adaptateur USB C vers USB A Rampow peut facilement connecter vos périphériques USB A (clavier, souris, disque flash USB, lecteur de carte, disque dur, contrôleur de jeu) aux téléphones et tablettes USB C équipés. Une option rentable pour utiliser au maximum et de manière créative vos périphériques USB précédents. 👍 [Transfert de Données Très Rapide] - USB 3.1 Gen 1 très rapide offre une vitesse de transfert incroyable (jusqu'à 5Gbps). Les données sont transférées 10x plus rapidement que les USB 2.0 traditionnels (480Mbps). Remplissez votre téléphone avec vos vidéos et photos préférées en quelques secondes. Compatible avec USB 3.0 / 2.0. 💯 [Connecteur Réversible Premium] - L'adaptateur USB type C peut être installé dans n'importe quelle direction pour des connexions sans tracas. L'adaptateur type C sans soudure et les contacts dorés offrent une conductivité exceptionnelle sans la perte de données. Fabriqué pour supporter plus de 10 000 insertions. 💗 [Léger et Compact] - La taille de poche et la portabilité font cet adaptateur USB C facile à transporter en tout temps. Une conception minimaliste et élégante va bien avec tous les appareils électroniques. 🌈 [Garantie à Vie] - Les adaptateurs USB C Rampow sont couverts par une garantie à vie. Veuillez nous contacter pour toute question ou préoccupation. Nous sommes le distributeur exclusif et le propriétaire de la marque "Rampow". Nous n'avons jamais accordé d'autorisation à d'autres vendeurs pour vendre notre marque ni nous les avons vendus pour revente. Assurez-vous de choisir Vendu par RAMPOW-FR!
Batterie de Rechange pour Microsoft Lumia 950 (Compatible avec Batterie d'origine BV-T5E) chiffon de nettoyage mungoo
Compatibilité parfaite : Le modèle de batterie rechange BV-T5E, conçu spécialement pour la Lumia 950, garantit une compatibilité parfaite. Modèle récent : La batterie a été récemment fabriquée. Avec une capacité de 3200 mAh à une tension de 3,85 V, cette batterie lithium-ion se distingue par une autonomie particulièrement longue. Pas d'effet mémoire : Avec la technologie Lithium-ion intégrée, cette batterie n'a pas d'effet mémoire et garantit une autonomie optimale, même après de longues périodes de charge partielle. Bon Ajustement : Cette batterie de téléphone intelligent impressionne par ses dimensions compactes et sa grande puissance. D'autres accessoires, comme un nouveau couvercle de batterie ou un nouveau chargeur ne sont pas nécessaires. Meilleure Qualité : Aves ses tests et inspections réguliers du produit, le fabricant garantit la meilleure qualité. Vous ne pouvez donc faire confiance qu'à une batterie rechargeable de qualité.
Câble USB Type C, AVIWIS [Lot de 4, 0.3m+1m+2m+3m] Chargeur USB C en Nylon Tressé Charge Synchro Rapide pour Samsung Galaxy S10/ S9 /S8 /Note 10 9,Huawei P20/ Mate20, Xiaomi MI A1, Sony Xperia XZ
【Avantages 0.3+1 +2+3M】Lot de 4 longueurs différentes (0.3M 1M 2M 3M) pour différentes distances de charge, elle vous convient dans divers endroits au lit/canapé/siège arrière de la voiture et dans la poche. 【Charge Synchro Rapide】AVIWIS Câble USB Type C supporte jusqu'à 5V / 3A de charge en sécurité, transfert standard jusqu'à 480 Mbps. (✘✘✘ Notes: Le câble ne pourrait pas supporter la Super Charge de Huawei et la Dash-charge de Oneplus) 【Compatibilité】Cordon USB C Compatibilité avec les smartphones USB Type C tel queSamsung Galaxy S10/ S9/ S8/ Note8/ A3/ A5/ A8, Huawei P30/P30 pro/P20/P10/Mate 20/Nova 4/3/2, Honor 10/9/8, Oneplus 6/5/5T, Xiaomi Mi A1/ A2/ Mi8, Motorola One/G6, LG G6, Sony Xperia, New Macbook, Nintendo Switch et d'autres périphériques USB 2.0 de Type C. 【Matériaux Premium】La veste en nylon ultra-solide rend ce chargeur usb c résistant à plus de 8000 flexions. Connecteur sans soudure et contacts dorés assurent une conductivité et une stabilité fiables et exceptionnelles. Conçus pour résister à plus de 10000 insertions, branchez et débranchez vos appareils sans aucun soucis. 【Garantie à Vie】L'achat comprend une GARANTIE A VIE assurée par AVIWIS. Service client efficace et facile à joindre pour résoudre tout votre problème en 24 heures.
Rampow RAMPOWT02 - Câble USB Type C à USB 3.0 - Câble USB C Nylon Tressé en Fibre - Gris Sidéral 2M/6.5ft [Nouvelle version]
[Compatibilité Etendue] - Compatible avec Samsung Galaxy S8, Google Nexus 5X / Nexus 6P / Pixel XL, OnePlus 2 / 3, Lumia 950 / 950XL, LG G5, HTC 10, Lenovo Zuk Z1, Huawei P9 / P10, Huawei Mate9, Apple New Macbook, ChromeBook Pixel, Pixel C, New Nokia N1 tablette et d'autres périphériques USB 2.0 / 3.0 de Type C. [Synchronisation et Charge Rapide] - Profitez de la vitesse de transfert et de la synchronisation Très Rapide de 5 Gbps avec des périphériques USB 3.0, qui est 10 fois plus rapide que USB 2.0 (480 Mbps). Il supporte jusqu'à 5V / 3A de charge en sécurité, vous permettant de recharger vos appareils plus rapidement que jamais! (Le câble ne pourrait pas supporter la Super Charge de Huawei et la Dash-charge de Oneplus) [Qualité Contrôle de 24 heures] - Chacun de nos câbles est testé sur 3 appareils type c différents pour une qualité de recharge optimale et fluide. Nos tests sont effectués dans des réalistes afin d'assurer une durabilité maximale au produit et prévenir tous dommages dus aux surcharges. [Matériaux Premium] - La veste en nylon ultra-solide rend le câble résistant à plus de 16 000 flexions. Connecteur sans soudure et contacts dorés assurent une conductivité et une stabilité fiables et exceptionnelles. Conçus pour résister à plus de 12 000 insertions, branchez et débranchez vos appareils sans aucun soucis. [Garantie à Vie] - L'achat comprend une GARANTIE A VIE assurée par Rampow. Service client efficace et facile à joindre pour résoudre tout votre problème en 24 heures. Nous sommes le distributeur exclusif et le propriétaire de la marque "Rampow". Nous n'avons jamais accordé d'autorisation à d'autres vendeurs pour vendre notre marque ni nous les avons vendus pour revente. Assurez-vous de choisir Vendu par Rampow!
